Does anyone know what this small grey icon next to my profile pic means / is significant of? I don’t recall ever seeing it in the past.
It is an image of the earth. It means that the server is being accessed remotely
If you say so… I showed that to no less than 6 people, and nobody guessed the earth. I can “kind” of see it now, but maybe some color to make that more apparent, or a description when you hover over it would be helpful.
what did they guess?
if they guess anything other than a planet or moon then you probably need to be asking different people next time you have a question about an icon.
i can’t imagine adding colour would make much difference
It just looks like some strange squiggles. So unless you know, it’s not very intuitive.
I will bring up to folks add a tool tip or maybe even add to a support doc describing that one and the warning icon when server unavailable.
(I should stop)
