Server Version#: 1.24.5.5173
Player Version#: 8.25.1.28703
Hi at all!
After some problems (fortunately solved) on my RAID, I had to recreate the docker container of my Plex installation.
Looking the log at the end of the container creation, there are some errors that I cannot resolve:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 01-envfile: executing... ,
[cont-init.d] 01-envfile: exited 0.,
[cont-init.d] 10-adduser: executing... ,
_ (),
| | ___ _ __,
| | / __| | | / \,
| | \__ \ | | | () |,
|_| |___/ |_| \__/,
Brought to you by linuxserver.io,
To support LSIO projects visit:,
https://www.linuxserver.io/donate/,
GID/UID,
User uid: 998,
User gid: 100,
[cont-init.d] 10-adduser: exited 0.,
[cont-init.d] 40-chown-files: executing... ,
[cont-init.d] 40-chown-files: exited 0.,
[cont-init.d] 45-plex-claim: executing... ,
[cont-init.d] 45-plex-claim: exited 0.,
[cont-init.d] 50-gid-video: executing... ,
[cont-init.d] 50-gid-video: exited 0.,
[cont-init.d] 60-plex-update: executing... ,
# Login via the webui at http://<ip>:32400/web #,
# and restart the docker, because there was no #,
# preference file found, possibly first startup. #,
[cont-init.d] 60-plex-update: exited 0.,
[cont-init.d] 90-custom-folders: executing... ,
[cont-init.d] 90-custom-folders: exited 0.,
[cont-init.d] 99-custom-scripts: executing... ,
[custom-init] no custom files found exiting...,
[cont-init.d] 99-custom-scripts: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
Starting Plex Media Server.,
Error in command line:the argument for option '--serverUuid' should follow immediately after the equal sign,
Crash Uploader options (all are required):,
--directory arg Directory to scan for crash reports,
--serverUuid arg UUID of the server that crashed,
--userId arg User that owns this product,
--platform arg Platform string,
--platformVersion arg Platform version string,
--vendor arg Vendor string,
--device arg Device string,
--model arg Device model string,
--sentryUrl arg Sentry URL to upload to,
--sentryKey arg Sentry Key for the project,
--version arg Version of the product,
--allowRetries arg Whether we will allow retries,
Critical: libusb_init failed
Can anyone give me some help to fix them?
Plex works, but I would still like to fix these errors ![]()
Thanks in advance to those who want to help me!
