Plex in Docker on OMV - errors on loading
Server Version#: 4.76.1
I am using OMV 5, with Docker and installing though Portainer. I am using the default image provided within Portainer lscr.io/linuxserver/plex:latest
After the Plex Media server starts the log file has this in it
Starting Plex Media Server.
[services.d] done.
Error in command line:the argument for option '--serverUuid' should follow immediately after the equal sign
Crash Uploader options (all are required):
  --directory arg       Directory to scan for crash reports
  --serverUuid arg      UUID of the server that crashed
  --userId arg          User that owns this product
  --platform arg        Platform string
  --platformVersion arg Platform version string
  --vendor arg          Vendor string
  --device arg          Device string
  --model arg           Device model string
  --sentryUrl arg       Sentry URL to upload to
  --sentryKey arg       Sentry Key for the project
  --version arg         Version of the product
  --allowRetries arg    Whether we will allow retries
Critical: libusb_init failed
It does actually run but is showing weird behavior. Allows me to add a folder to the library but finds nothing in the folder (there are about 400 movies in subfolders}.
Any help would be appreciated.
Might be helpful to provide the command line in question…
My docker run command is:
  docker run \
    -d \
    --name plex \
    --network=host \
    -e TZ="America/Los_Angeles" \
    -e LANG="en_US.UTF-8" \
    -e PLEX_UID=297536 \
    -e PLEX_GID=297536 \
    -h Jupiter \
    -v /volume1/PlexMediaServer/AppData:"/config/Library/Application Support" \
    -v /volume1/PlexMediaServer/AppData/tmp:/tmp \
    -v /volume1/PlexMediaServer/AppData/tmp:/transcode \
    -v /volume1/Media/Videos:/Videos \
    -v /volume1/Media/Pictures:/Pictures \
    -v /volume1/Media/Music:/Music \
    --device=/dev/dri:/dev/dri \
    plexinc/pms-docker:plexpass
This is on my Synology PMS. You might want to try to get it run as a plain docker run command before getting it run under Portainer.
As its a preconfigured script it makes it difficult to determine where it actually comes from. I’m rather a newby with Portainer so I am not sure where to find that info.
Can you read/post this preconfigured script?
Can you try just running the docker run command I posted? Of course, you’ll need to adjust the parameters to your environment. For example, you’ll need to change your plex UID and GID. The volume mounts (-v args) will have to be adapted to your paths.
