Help me understand the logs for this issue - Is this an audio track issue?
Server Version#: Version 1.32.5.7516
Player Version#: Apple tvOS version unknown
My dad is getting an error Playback Stopped, Neither direct play nor conversion is available. Looking in the logs I see below leads me to think if I convert/add an audio track at a lower bitrate it would play? Am I understanding that correctly?
Thank you
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4/Req#672eb8a] We're going to try to auto-select an audio stream for account 11950227.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4/Req#672eb8a] Selecting best audio stream for part ID 652706 (language: )
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4/Req#672eb8a] Audio Stream: 2346846, Subtitle Stream: -1
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Applying codec restriction restrict-transcode-target-codec(audioCodec=aac&context=streaming&protocol=hls&type=videoProfile&videoCodec=h264) on 637C3EC4-4E0A-4290-8BEC-66B49F266A65
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Codecs: testing h264 (decoder) with hwdevice vaapi
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Codecs: hardware transcoding: testing API vaapi for device '/dev/dri/renderD128' (CometLake-S GT2 [UHD Graphics 630])
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x41524742 -> bgra.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x42475241 -> argb.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x41424752 -> rgba.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x52474241 -> abgr.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x58524742 -> bgr0.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x42475258 -> 0rgb.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x58424752 -> rgb0.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x52474258 -> 0bgr.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30335241 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30334241 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30335258 -> x2rgb10le.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30334258 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x36314752 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x50424752 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x50524742 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x56555941 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30303859 -> gray.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x3231564e -> nv12.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x3132564e -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x32595559 -> yuyv422.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x59565955 -> uyvy422.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x32315659 -> yuv420p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30323449 -> yuv420p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x50313134 -> yuv411p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x48323234 -> yuv422p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x56323234 -> yuv440p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x50343434 -> yuv444p.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x33434d49 -> unknown.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] [FFMPEG] - Format 0x30313050 -> p010le.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Codecs: Testing with profile 'High'
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Selected protocol hls; container: mp4
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: analyzing media item 473683
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): Direct Play is disabled
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): media must be transcoded in order to use the hls protocol
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): no direct play video profile exists for http/mkv/h264
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): no direct play video profile exists for http/mkv/h264/ac3
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): Direct Streaming is disabled, so video stream will be transcoded
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): no remuxable profile found, so video stream will be transcoded
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Cannot direct stream video stream due to profile or setting limitations
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Cannot direct stream audio stream due to profile or setting limitations
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] MDE: Movieman (1978): selected media 0 / 473683
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Required bandwidth unknown (media requires deep analysis) Changing decision parameters provided by client to fit bandwidth limit of 320kbps
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Determining preferred transcode encoders through transcode only decision.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Could not fit playback within bandwidth limit of 320kbps
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Reached Decision id=241435 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4004,Not
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Terminating session 0x7fc487cac2f8:637C3EC4-4E0A-4290-8BEC-66B49F266A65 which is using 11932kbps of WAN bandwidth.  Used is now 20795kbps
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Terminating session 0x7fc487cac2f8:637C3EC4-4E0A-4290-8BEC-66B49F266A65 which is using transcoder slot.  Used slots is now 1
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Killing job.
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Signalling job ID 162271 with 9
DEBUG - [Req#672eb67/Transcode/2F0C3CD0-9A58-422C-991D-0816B056D2E4] Streaming Resource: Terminated session 0x7fc487cac2f8:637C3EC4-4E0A-4290-8BEC-66B49F266A65 with reason Neither direct play nor conversion is available.
