Thanks for all your help Chuck! It should not have taken us days to figure this out, but the SNAP was the main issue.
ChuckPA One thing did not work correctly. The drobo still does not mount on boot. It’s not a big deal since I also learned the basics of rsync and will hopefully have the drobo empty soon enough, so I can repurpose those drives.
Thanks again Chuck. You’re quite possibly the most helpful support person I’ve ever worked with.
look through the systemctl list-units | less output for the one mentioning the drobo.
By name, specifically systemctl enable it. It might make a difference.
Also, should we need PMS to wait until after that service starts, we can add the After qualifier to the PMS override.conf file we created. This will guarantee it waits for the service to start.
We have had to add After clauses on Intel NUC systems because they would often start PMS before the network was initialized. (Imagine that chaos)
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d2-2\x2d2:1.0-host7-target7:0:0-7:0:0:0-block-sdh-sdh1.device loaded active plugged 5D Microsoft\x20reserved\x20partition
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d2-2\x2d2:1.0-host7-target7:0:0-7:0:0:0-block-sdh-sdh2.device loaded active plugged 5D Big_Drobo
sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d2-2\x2d2:1.0-host7-target7:0:0-7:0:0:0-block-sdh.device loaded active plugged 5D
The middle one reporting sdh2 is the correct one. I’m unsure of what you mean by “By name” enable it. Is the name 5D Big_Drobo? I tried the following but am probably noobing it up…
PMS isn’t the cause. The drobo driver service isn’t starting up fast enough. PMS gets started and starts looking for the drobo (it doesn’t know better) too soon.
We simply delay PMS start until after we know the drobo is ready.
As for the units to look for, you want the “mount” references. they look like these.
-.mount loaded active mounted Root Mount
backup.mount loaded active mounted /backup
boot.mount loaded active mounted /boot
chuck.mount loaded active mounted /chuck
dev-hugepages.mount loaded active mounted Huge Pages File System
dev-mqueue.mount loaded active mounted POSIX Message Queue File >
home-chuck-git.mount loaded active mounted /home/chuck/git
home.mount loaded active mounted /home
proc-sys-fs-binfmt_misc.mount loaded active mounted Arbitrary Executable File>
run-user-1026-gvfs.mount loaded active mounted /run/user/1026/gvfs
run-user-1026.mount loaded active mounted /run/user/1026
run-user-42.mount
On my system, these are part of the cgroup. This means they get setup with normal startup.
It makes me wonder if Ubuntu 18 is doing cgroups differently than the driver app expects
(wouldn’t be the first time)
eckomega@eckomega-mediaserver:~$ systemctl enable iscsid.service
Failed to enable unit: Unit file iscsid.service does not exist.
This is a line from http://drobo-utils.sourceforge.net/ I’ve been weary of adding any addition variables to this project so I haven’t installed this program.
Linux drivers make disk, cdrom, and other peripherals, look like SCSI peripherals to applications. Regardless of the physical connection, it is a normal part of the linux kernel to make the device appear as a so-called “generic SCSI” one.
Is there any guide to mounting an external filesystem for Snap-installed Plex out there? I’ve seen talk of bind mounting or symlinking inside the snap environment FS, but that talk seems to always end with ‘that didn’t work’…
