Server Version#: 1.18.3.2129
Player Version#: Misc Android, Web, iOS, Chromecast (tv dongle)
Hi all - I recently deleted my old 11.1 FreeNAS PlexPass jail and reinstalled a fresh 11.2 version. I am now having various issues playing back different newer videos on different devices.
Some files play fine. These mostly seem to be files that need no transcoding.
Most recent files exhibit the same symptoms and do not play successfully:
- Are MKV’s
- Most (but not all) require transcoding of at least the audio.
- The impacted videos (for iOS, Chrome webplay, and Chromecast’ed streams) will show the “spinner” endlessly when playing back (instead of playing), while the timecode shows 0:00 and the dashboard shows no activity. But press pause on the devices, and click play again, and the stream shows up on the dashboard, with the status as playing, with correct timecode and a thumbnail image of where the stream is up to. Pressing pause on the device again will pause it on the dashboard, and resuming will resume. But at no stage does anything play on the devices. It still shows the spinner.
- Not all devices have the same problems - Android app seems to do OK for some of the files, but “casting” to chromecast will yield the same results as the point above. Yet Android app will also have the same problems as above. I cannot find a common cause.
I suspected the transcoder, and access to the transcode folder. However, I have set this up as both a mount point and also as a local folder to test, with rwe permissions of 777 - I can see the transcoder making new folders and heaps of chunked files with proper file sizes. So I don’t think its a path or permission issue.
Bandwidth and CPU graphs all show something is happening.
I found the following items of interest in the debug logs (film was “Cars”):
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Selected protocol dash; container: mp4
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: analyzing media item 5269
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cars: Direct Play is disabled
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cars: media must be transcoded in order to use the dash protocol
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cars: no direct play video profile exists for http/mkv/h264
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cars: no direct play video profile exists for http/mkv/h264/ac3
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cannot direct stream audio stream due to codec ac3 when profile only allows aac
Dec 27, 2019 16:42:14.739 [0x812837000] Debug — MDE: Cars: selected media 0 / 5269
It’s as if there is no MKV codec.
And this appears a few times too:
Dec 27, 2019 16:42:29.405 [0x80bdbdc00] Warning — Transcode runner appears to have died.
Plex itself is saying an update is available: 1.18.3.2156. However, FreeNAS 11.2 plugin interface is not detecting any updates, and my understanding is as of v11.2 we should be using Freenas to update plex, not scripts? An “apt upgrade” shows no new packages. I’ve seen the old “wget” script doesn’t work under 11.2, and I’ve not found an instruction on manual updates yet, so I’ve not pushed this further.
Any help would be greatly appreciated.
I would post full logs, but the exceed the post limit. Any requests?
Ent.
