Hi all - Garmin SubMusic plugin released an update that supports Plex API, however Garmin SDK only supports Port 80 and 443.
Normally, I would just change those ports inside the Plex settings to expose 443, but I’m running Plex in a docker container on unRAID and changing this requires changing host mode which breaks other things.
I think I then need to setup a reverse proxy on the docker server to redirect traffic to the custom Plex port 80 and 443, but I’m unclear where to start on this or if this is the right answer.
I found a guide here but not sure if I should spend time trying it.
Anyone have any ideas?
