Help running AppImage
Player Version#: 3.4.0
OS: Fedora 33, Gnome 3.38
I placed the appimage in ~/.local/bin/ and tried to launch it from terminal.
I noticed that Plexamp was able to automatically download 3.4.0 and update itself (thus changing the path to ~/.local/bin/Plexamp-3.4.0.AppImage.
When I ran this the first time, I saw the loginscreen and logged in to find only a gray screen. This occurs on both 3.3.x and 3.4.0.
I think Fedora may be a hard target for an AppImage because it uses PipeWire/Wayland, and PlexAmp may not be able to speak to PipeWire via the PulseAudio api.
Fontconfig warning: "/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf", line 6: unknown element "reset-dirs"
Started Media Service: false
Linux: Registering MPRIS service.
[17749:1216/171923.635600:ERROR:buffer_manager.cc(488)] [.DisplayCompositor]GL ERROR :GL_INVALID_OPERATION : glBufferData: <- error from previous GL command
(node:17755) Electron: Loading non context-aware native modules in the renderer process is deprecated and will stop working at some point in the future, please see https://github.com/electron/electron/issues/18397 for more information
Checking for update
Update for version 3.4.0 is not available (latest version: 3.4.0, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
(node:17755) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
This is where output stops.
I know Electron.js has added Wayland native support only recently, but I expected it to launch in an xwayland context at least.
Is there anything this output can hint to helping get PlexAmp to run on my machine?
I’m seeing these logs as well, running cinnamon on X. My behavior is different though, the app never launches.
 ~/bin » ./Plexamp-3.4.0.AppImage
system info
        System:    Kernel: 5.9.14-200.fc33.x86_64 x86_64 bits: 64 compiler: gcc v: 2.35-15.fc33)
                   Desktop: Cinnamon 4.6.7 tk: GTK 3.24.24 wm: muffin dm: GDM, LightDM
                   Distro: Fedora release 33 (Thirty Three)
        Machine:   Type: Desktop System: Dell product: Precision Tower 3430 v: N/A serial: <filter>
                   Chassis: type: 3 serial: <filter>
                   Mobo: Dell model: 00CV7F v: A00 serial: <filter> UEFI: Dell v: 1.2.26 date: 11/30/2018
        Battery:   Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
                   serial: <filter> charge: 100% (should be ignored) status: Discharging
        CPU:       Info: 6-Core model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Kaby Lake rev: A
                   L2 cache: 12.0 MiB
                   flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 76799
                   Speed: 883 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
                   5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
        Graphics:  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
                   chip ID: 8086:3e92
                   Device-2: NVIDIA GP107GL [Quadro P1000] vendor: Dell driver: nvidia v: 455.45.01
                   bus ID: 01:00.0 chip ID: 10de:1cb1
                   Display: x11 server: Fedora Project X.org 1.20.10 driver: modesetting,nvidia
                   unloaded: fbdev,nouveau,vesa alternate: nv resolution: 1: 2160x3840~60Hz
                   2: 3840x2160~60Hz s-dpi: 96
                   OpenGL: renderer: Quadro P1000/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01 direct render: Yes
        Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
                   bus ID: 00:1f.3 chip ID: 8086:a348
                   Device-2: NVIDIA GP107GL High Definition Audio vendor: Dell driver: snd_hda_intel
                   v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
                   Device-3: Cambridge Silicon Radio Audioengine 2+ type: USB
                   driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5:7 chip ID: 0a12:1243
                   Device-4: Logitech HD Webcam C615 type: USB driver: snd-usb-audio,uvcvideo
                   bus ID: 1-10.2:12 chip ID: 046d:082c
                   Device-5: SteelSeries ApS SteelSeries Arctis 1 Wireless type: USB
                   driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-2:3 chip ID: 1038:12b3
                   Sound Server: ALSA v: k5.9.14-200.fc33.x86_64
