Server Version#: latest stable always
Player Version#: various
I’ve been using AppImages to run plexamp on linux mint clients on my LAN, currently 4.12.4. It is reasonably well behaved .
Today I downloaded plexamp 4.13.1 appimages to two PCs. On both when started it opens and stays on a blank window or form. No logs are created in the expected usual place (./cache/plexamp…)
Any clues as to what might be happening?
UPDATE: I thought I had it fixed, but not really. Running the appimage on LMDE7, which is wayland AFAIK, initally it’s back to the blank window and no log. Starting it from the shell I get
./Plexamp-4.13.1.AppImage
Main: restoring window state from /home/pierre/.config/Plexamp/window-state-plexamp-main.json
Linux: Registering MPRIS service.
Checking for update
Update for version 4.13.1 is not available (latest version: 4.13.1, downgrade is disallowed).
checkForUpdatesAndNotify called, downloadPromise is null
After a couple of minutes the plexamp starts to render on a white background and a timer cursor.
Same here. I’m running the AppImage on my chromebook. 4.12.4 worked fine, but I just get a blank UI when I load it up.
My hunch would be something to do with wayland, but using GDK_BACKEND=x11 didn’t make a difference.
Here’s what I see when I start it from the terminal:
davidlumm@penguin:~/Applications$ ./Plexamp-4.13.1.AppImage
[29322:0417/093522.394865:ERROR:ui/ozone/platform/wayland/common/drm_render_node_path_finder.cc:45] drmGetDevices2() has not found any devices: No such file or directory (2)
[29322:0417/093522.908290:ERROR:ui/ozone/platform/wayland/host/wayland_zwp_linux_dmabuf.cc:306] drmGetDeviceFromDevId() returned an error: No such file or directory (2)
[29383:0417/093523.240808:ERROR:ui/ozone/platform/wayland/common/drm_render_node_path_finder.cc:45] drmGetDevices2() has not found any devices: No such file or directory (2)
Main: restoring window state from /home/davidlumm/.config/Plexamp/window-state-plexamp-main.json
Checking for update
I don’t use mint or chromeos (I’m on fedora) however have you tried installing the flatpak version ? I have mint on a VM and it worked okay. It was confirmed here Plexamp Appimage Lost Icon(s) - #2 by aubrey.wodonga that the recommendation from plex development is to not use the AppImage and to use flatpak instead.
(There was a major upgrade to Electron, which supposedly helped some things, but apparently broke others; sadly kind of par for the course with desktop Linux )
4.13.2 unfortunately didn’t fix it. After a bit of debugging with my mate ChatGPT I’ve tried a variety of different flags etc to resolve this issue, but there appears to be some stuff hardcoded in the later version of electron that isn’t present in the older versions. Such is life, as you say.
For now I’ve prevented auto-update by locking the intermediate folder: chmod -R -w ~/.cache/plexamp-updater/ and downgraded to 4.12.4. I’ll try again in a while when ChromeOS has had some updates and hopefully electron has too
Another option for Linux desktop users who’d like to run Plexamp is the headless version. (Ignore that it says it’s for Raspberry Pi; it supports x86-64 as well.)
You can control it via your mobile device if you use Plexamp there, or you can use its embedded web app (http://ip.addr.of.host:32500).
I’ve installed on my server hosting pms, have it running under systemd, which in turn says “running”. But how in the world to I access it and control it. The advice is got to http://host:32500 - which times out very nicely.
Did you claim it yet? For the first run, you should run it directly from the command line using something like: node /path/to/plexamp/js/index.js
It should direct you to visit https://plex.tv/claim to obtain a claim code and enter. After doing so, you should see a message that Plexamp is signed in and ready, after which it will exit. You can then run it again from the command line or via a systemd service.
