Help! "We failed to reach a server. Reason: [Errno 11001] getaddrinfo failed"
Hello all,
I have never used PlexConnect before, and had a 3rd gen AppleTV that I wasn’t really using, so I figured I can set it up for a friend.
The PMS is on a Windows 10 64 bit machine, all updated. PMS is also latest PlexPass version. Apple TV is 3rd gen, latest firmware.
I’ve tried to signin to myplex, and also signed out, and AppleTV simply doesn’t see the local PMS. It sees my two shared servers, but not the local one.
There is also an Xbox One on the network, and the Xbox One’s Plex app sees the PMS just fine.
The network here is under VPN through DD-WRT router, but I don’t care about having access to see this server from the outside.
Help?
``15:04:58 PlexConnect: ***
15:04:58 PlexConnect: PlexConnect
15:04:58 PlexConnect: Press CTRL-C to shut down.
15:04:58 PlexConnect: started: 15:04:58
15:04:58 PlexConnect: Version: 0.5-dev-211015
15:04:58 PlexConnect: Python: 2.7.10 (default, May 23 2015, 09:40:32) [MSC v.1500 32 bit (Intel)]
15:04:58 PlexConnect: Host OS: win32
15:04:58 PlexConnect: PILBackgrounds: Is PIL installed? False
15:04:58 PlexConnect: IP_self: 192.168.4.44
15:04:58 DNSServer: started: 15:04:58
15:04:58 DNSServer: ***
15:04:58 DNSServer: DNSServer: Serving DNS on 192.168.4.44 port 53.
15:04:58 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.4.44
15:04:58 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
15:04:58 DNSServer: forward other to higher level DNS: 10.30.0.1
15:04:58 WebServer: started: 15:04:58
15:04:58 WebServer: ***
15:04:58 WebServer: WebServer: Serving HTTP on 192.168.4.44 port 80.
15:04:59 WebServer: ***
15:04:59 WebServer: WebServer: Serving HTTPS on 192.168.4.44 port 443.
15:05:06 DNSServer: DNS request received!
15:05:06 DNSServer: Source: (‘192.168.4.24’, 60819)
15:05:06 DNSServer: Domain: se-cdn.itunes-apple.com.akadns.net
15:05:06 DNSServer: ***forward request
15:05:06 DNSServer: -> DNS response from higher level
15:05:06 DNSServer: Source: (‘192.168.4.24’, 51578)
15:05:06 DNSServer: Domain: itunes-cdn.itunes-apple.com.akadns.net
15:05:06 DNSServer: Source: (‘192.168.4.24’, 64824)
15:05:06 DNSServer: Domain: pd-st.itunes.apple.com
15:05:07 DNSServer: -> DNS response from higher level
15:05:09 DNSServer: DNS request received!
15:05:09 DNSServer: Source: (‘192.168.4.24’, 63184)
15:05:09 DNSServer: Domain: trailers.apple.com
15:05:09 DNSServer: ***intercept request
15:05:09 DNSServer: -> DNS response: 192.168.4.44
15:05:09 WebServer: serving /js/application.js
15:05:09 WebServer: serving .xml: /
15:05:09 PlexAPI: ***
15:05:09 PlexAPI: poke plex.tv - request Plex Media Server list
15:05:09 DNSServer: Source: (‘192.168.4.24’, 62951)
15:05:09 DNSServer: Domain: a1.da1.akamai.net
15:05:09 DNSServer: ***forward request
15:05:10 DNSServer: -> DNS response from higher level
15:05:12 PlexAPI: No Response from Plex Media Server
15:05:12 PlexAPI: We failed to reach a server. Reason: [Errno 11001] getaddrinfo failed
15:05:12 PlexAPI: Traceback:
Traceback (most recent call last):
File “C:\Program Files (x86)\PlexConnect-master\PlexAPI.py”, line 406, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “C:\Python27\lib\urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “C:\Python27\lib\urllib2.py”, line 431, in open
response = self._open(req, data)
File “C:\Python27\lib\urllib2.py”, line 449, in _open
‘_open’, req)
File “C:\Python27\lib\urllib2.py”, line 409, in _call_chain
result = func(*args)
File “C:\Python27\lib\urllib2.py”, line 1240, in https_open
context=self._context)
File “C:\Python27\lib\urllib2.py”, line 1197, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 11001] getaddrinfo failed>
15:05:15 PlexAPI: No Response from Plex Media Server
15:05:15 PlexAPI: We failed to reach a server. Reason: [Errno 11001] getaddrinfo failed
15:05:15 PlexAPI: Traceback:
‘_open’, req)
raise URLError(err)
‘_open’, req)
raise URLError(err)
15:05:15 PlexAPI: Servers (local, plex.tv, MyPlex): 3
15:05:15 WebServer: serving .xml: /PlexConnect.xml
15:05:16 WebServer: serving /js/utils.js
15:05:16 WebServer: serving /js/handlePlexConnectNavbar.js
15:05:16 WebServer: serving .xml: /library/sections
15:05:18 WebServer: serving /js/utils.js
15:05:18 WebServer: serving /js/sectionHoldSelect.js
15:05:18 WebServer: serving .xml: /library/sections/1/recentlyAdded
15:05:20 WebServer: serving .xml: /
15:05:20 WebServer: serving /js/utils.js
15:05:21 WebServer: serving /js/settings.js
15:05:21 WebServer: serving *.jpg: /thumbnails/PlexConnectLogo.jpg
15:05:24 WebServer: serving .xml: /``
anyone care to chime in?
Hello said you managed to solve your problem
