First - thanks to everyone who helped with my other question.
I have decided to go with the QNAP TS-453Be which I will use for general NAS storage, Media storage and also running PLEX.
Now I am looking at drives to put in it - I am thinking of starting with 3 - 6TB drives running in Raid-5 for 12TB of storage and have the ability to easily add another 6TB when I need it.
Now for my questions -
5400 vs 7200 RPM - will I really see any difference?
Does the Cache size matter WD Red has 64MB where the Segate Ironwolf has 128MB?
Suggestions WD Red vs. WD Red Pro vs WD Gold vs Segate Ironwolf
I would recommend inventing the few extra $$ for the following reasons:
5400 RPM drives do have a bit of a ‘sluggish’ feel to them. Great for general storage and normal streaming but when you’re accessing a lot of files (e.g the Plex metadata database), there is a distinct difference. The math is: 7200 RPM is 50% faster in positioning the sector under the heads.
The WD Red Pro 8TB drives are the same 128 GB cache and come with a 5 year warranty. The 6TB drives have the 64MB cache.
To date, I have only had trouble with the first group of WD Red drives (a firmware issue only) some 6 years ago. Since then, they have been flawless and run 24/7/365.
WD Red Pro 8TB 3.5-Inch SATA III 7200rpm 128MB Cache NAS Internal Hard Drive (WD8001FFWX)
I currently have 112TB of raw storage, all with WD Red Pro drives (8x 6TB and 8x 8TB). I outgrew the 6TB drives quickly so made the jump to 8. Now I am much more future proof for my needs.
