Here is an idea
Make it easy to find out how to and where to insert Raspberry Pi mpeg-2 and vc codecs.  Like in the "how to install" or the FAQ.
I managed to figure it out once, but cannot do it again!
OK, here's a 'how to edit RPi license codes' guide. But after reading this once I doubt you will ever need it again...
1: Shutdown your RPi, and then disconnect its power
2: Remove the SD card from the RPi
3: Insert the SD card in card reader/writer of a PC
4: Use a PC text editor to edit "config.txt" on the SD card
5: Edit the license code lines in "config.txt", also removing any commenting hashmarks (leading "#" character on a line)
6: Save the edited file back to the SD card
7: Remove the SD card from the PC
8: Insert the SD card into the RPi
9: Turn on the RPi by reapplying its power
NB: This method is not specific for RasPlex, but also works for other RPi operating systems (all share the same basic boot method).
Best regards: dlanor
Thank you.
