Question re the newest version of the iOS client - it states it now has builtin support for HEVC videos, but I am unable to get this to work. Posted this as a comment in the open forum but no reply there. Essentially, I have checked the 4cc code, made sure I have compatible audio streams (using AC3), and am using what I believe to be an adequately powered device - an iPad Pro and an iPhone 8. My server software elects to automatically transcode.
I’m running Plex on a ReadyNas from netgear, the 212 (recommended NAS). Would this make a difference? I have added H265 as a profile to iOS.xml on the server in the hope this would make a difference.
Thanks for the reply. I’ve similarly altered iOS.xml as mentioned with no effect. I even just cloned your iOS.xml (thank you for supplying a slightly different example from the one I had modified), the following is a screengrab from plex server:
As you can see, it’s still transcoding h264 from HEVC.
The FourCC code of the relevant file (a x265 code film) is hvc1, which i have confirmed by running it through ffmpeg to ensure that it’s the correct code. Can be seen here (file metadata):
At present, it’s a non-function for me and a bit of an irritant. Any other thoughts?
DirectPlay is of course turned on in the app preferences. It’s only the HEVC encode that is causing this difficulty.
The other thing I ran into on my wife’s iPad – in the Plex client I had to go into Settings -> Quality, and set Home streaming to “Maximum”.
Does the “Plex Media Server.log” give any indication as to why it is transcoding? Enable Verbose and/or debug logs for the server, try to play the file, and then download the logs. Look in the “Plex Media Server.log” for any line that has MDE: in it. That line, or the lines around it, should tell you why the server is transcoding.
Thanks kclimie - turns out it was the setting to Maximum quality. 20MBPs apparently wasn’t enough - great pickup. Set that to maximum and then… boom. Streams.
