Server Version#: 1.18.7.2438 Synology 218+
Player Version#: 6.7.2 iOS
I have recorded TV 1080i (MPEG2VIDEO) (hw) that I play on different devices. When Plex transcodes this video to 1080P (H264) — Transcode (hw) the video plays fine. However, when Plex transcodes to 1080P (HEVC) — Transcode (hw), I get 2 seconds of playback, then buffering along with the message “The server is not power enough to convert this video for smooth playback”, then the video buffers for ~90 seconds, plays for ~120 seconds, buffers for ~90 seconds, etc… I have hardware accelerated encoding enabled (things get much worse with it disabled). I assume this transcoding to HVEC is maxing the hardware encoder?
This behavior is only seen on my iOS client - presumably because this client supports HVEC; while other clients support H.264. Is there a way to control transcoding so Plex just transcodes to H.264? Or another solution I’m not considering?
Here is the behavior I’m seeing. The stream on the left is being transcoded to H.264 and works. The stream on the right is being transcoded to HVEC and has significant buffering.
Not everyone can have it due to device limitations. As it being seen now, the iOS client is accepting HEVC DirectPlay / DirectStream.
Further, not all servers can reasonably produce HEVC due to the complexity of encoding it versus the resources available. Some CPUs do not have the required power.
I appreciate all the verification. As the HEVC transcode feature is developed, I wonder if there can be a knob to control its use? It’s clear that at 1080, my little Synology 218+'s Celeron J3355 just can’t quite encode in real-time.
There is a knob to control its use but that knob is hard coded.
It also requires a player which can meet the requirements.
Not all players are capable of fragmented MP4 (fMP4)
Now that I know what is happening, I have been able to tweak the quality setting in the iOS app for Home Streaming to 8 Mbps 1080p HD. This is resulting in h.264 encodes to iOS devices. This is enough of a knob for me to get streaming performance back where it needs to be for my setup.
