Server Version#:1.18.9.2578-513b381af
Player Version#:6.10
When playing certain HEVC streams with AAC 5.1, the video is very stuttery and jerky. If I enable experimental player, this does not happen. Also, if I transcode to x264, it also works fine. What could be the issue? I have tried playing the video on VLC, and it works without issue. Also, according to playback info, the video is playing at twice the bit rate it actually is, and therefore it appears the player is double playing every frame?
Issue essentially fixed on newest version of plex that enables enhanced video player for all users.
Having the same issue. Any idea when the feature will be released? Thank you
Currently scheduled for next week but things could change.
Stutter still happend on iPad and AppleTv4k with Plexplayer. iOS player works fine. The files are encoded with Nvidia hardware nvencc64, quality VBR. Infuse works fine. Please fix.
Hint: I enable under Help āshow informationā and there I can see that dropped frames is increasing (5-10 pictures every second)
The files youāre dealing with are - BROKEN.
If waiting for Plex to maybe come up with a solution isnāt something you want to do - you can fix them:
The bad news:
They require fixing at this time.
The good news:
Iāve only got 506 left to fixā¦
why there are broken ?
This is the commandline:
NVEncC64. exe --avhw --vbrhq 10000 --codec h265 --preset quality --output-depth 10 --master-display āG(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)ā --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --max-cll ā3241,902ā --aud --crop 0,280,0,280
Mediainfo:
Format : Matroska
Format version : Version 4
File size : 10.1 GiB
Duration : 2 h 13 min
Overall bit rate : 10.8 Mb/s
Encoded date : UTC 2020-05-02 07:39:35
Writing application : mkvmerge v45.0.0 (āHeaven in Penniesā) 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 9 906 kb/s
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.067
Stream size : 9.26 GiB (92%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 3241 cd/m2
Maximum Frame-Average Light Level : 902 cd/m2
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 429 MiB (4%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Plays fine on Shield, FireTV4k an LG TV.
Problems on Ipad pro and AppleTV 4k with new player.
Old player plays fine.
That doesnāt look like one of the files Iām talking about, butā¦
If you run those āoriginal troublemakers described in that threadā through V45 of MKVToolNix - it fixes 'em.
Looks like the issue you have isnāt with the file.
Iāve got 477 to goā¦
