i have plex on my smart tv but i have a friends account linked to it but i have now set a server up on my pc is there a way to have both accounts linked to my smart tv ???
You can’t be logged into two servers at once, but if you ask your friend to share his libraries with you, you can still have access to his media while you are logged into your own server.
Yes. If you have shared both servers to the account that is logged into the TV, both should be available.
Try this as a starter: https://support.plex.tv/articles/navigating-the-big-screen-apps/
If your tv is logged in with your friends plex account, you will need to log it out, then log in with the same account used on your server.
That would let access your server.
Your friend would need to invite your account to his server, then you can access both servers.
You can also invite his account, and then he can access your server.
Not sure if this has been over thought by my fellow forum members. I have a friend libraries and my server libraries pinned to my left menu and works well on my LG TV. Just navigate to the more option at the bottom of left menu and add your friends Libraries by pin. You can also rearrange there order.
These functions can also be done on your server.
If I have misunderstood your help request, I do apologize.
I use a LG WebOS TV
