I have just started using Rasplex on my model B and was wondering if it was possible to hide items from the PHT Dashboard such as Watch Later, Channels and Search to clean up the menu?
Go to your server, you can also do this here at https://app.plex.tv/web/app
Go to Settings > Dashboard and enable/disable what you do/don’t want to show, you can also prioritise them by click on the icon (with 3 black stripes) and dragging it up or down depending on where you want it to appear on the dashboard.
@blu3_v2 said:
Hi,I have just started using Rasplex on my model B and was wondering if it was possible to hide items from the PHT Dashboard such as Watch Later, Channels and Search to clean up the menu?
Not with the default skin, install @DeadEyeFlint Plex Black Edition skin and you can customise the Home screen in a number of ways. Look in the skins sub forum.
Regards
