i have been plagued by a stutter on some high bitrate video files. this, despite taking out the dts-hdma audio stream that seems to cause problems. so, i started to look into overclocking...
this improved the situation, but after playing for some time the file would start to stutter again (and rasplex would become basically un-responsive). so i looked into over-clocking.
the temperature of the rpi stayed around 62c, but i noticed that the cpu frequency would drop back to 700 mhz, and stay stuck there during the stutter despite being overclocked to 950 mhz.
i think the ondemand governer is dropping the cpu frequency during a 'lull' and then it never comes back because of the stutter. the ondemand up_threshold is 95% cpu by default, so i dropped it down to 60%. et voilà, no stutter !
unfortunately, this change is lost at every reboot. i read somewhere that a rc.local file could be created with "echo 50 > /sys/devices/system/cpu/cpufreq/ondemand/up_threshold" in /etc. but i can not get access to this directory (it is read only).
i also tried inserting this command into autostart.sh, but when i check it has either not worked, or been overwritten.
what do you think. and how can i make the threshold change persist ?
...So how did it work out? The stuttering is an inconvenience I've experieced, and is one of the things keeping me from making a Rasplex unit available to the rest of the family. Whenever I put something out for everyone else to use, they somehow expect me to fix anything that doesn't work :)
So i got it running at 950 MHz now, set the up_threshold to 50 but it is still running at 100% with 2,94 Mb/s h.264 720p file. Even tho i buffered 25% i can not watch a single episode without stuttering.
edit: is there a reason why we are not overclocking core_freq instead of gpu_freq and or h264_freq? Now running at 1GHz and 500MHz for the core, still running at 100%
So i tried powerlan, got a total of 13Mbit/s :( Now i ordered two WLAN Bridges Netgear and TP-LINK and a Netgear N300 Micro dongle.
On my laptop i got 80Mbit via WLAN.
you can`t compare your pi and laptop, your laptop has a lot more cpu power, more memory, faster disk and so on. the network is based on the usb 2 controller on the pi which delivers bandwidth to network, usb and sd card. that means that everything has about 400 mb/s to share.
Just finished setting up Rasplex on B-version 512MB. Setup went nicely following the instructions. Had zero problems and the system was fully functional after completing the initial Rasplex setup wizard.
But it seems like the current version cannot handle high bit rate (~10Mbps) 1080p movies at all. 720p movies play (~4Mbps) fine with no evident problems but 1080p movies simply start to stutter and go off lip-sync in about 1 minutes into the movie. My pie is connected through wired connection.
Most of my movies are BR rips with bitrates 8+ Mbps and some go beyond 20Mbps. I have no problems using either Win8 PHT or Samsung Plex app to watch these. I saw someone mentioning having problems even with 720p at 4Mbps. So what is actually considered high bit rate?
Edit: Just took a look through SSH on CPU usage. For 720p 4Mbps it 60-70% and for 1080p 8Mbps it was fluctuating between 65% and 96%. High bit rate scenes clearly caused a higher CPU usage and the most highest ones caused complete stutter/off-sync. Player however recovered from this if I jumped forward. Is there any chance that this could be caused by bad power supply as some one suggested? I'm using a Nokia quality supply suggested by the dealer I got the Raspberry from.
Edit2: Also there seems to be quite a lot of work still to be done to get this to a usable level. Fully understand this is marked as beta but I would say this is more like alpha or proof of concept. And this is with no disrespect to the devs, I'm just saying this is no way near to be usable for an average user and might give a totally wrong impression what Plex can really do especially if this would be the first Plex client you try out. I'm comparing this to PMC or PHT running on PC and I'm a bit amazed about some of the comments that they are running this just fine.
Edit3: Followed this guide to install raspbmc + plexbmc to see whether this issue is rasplex or raspberry related. Turns out that the CPU usages are way lower on the latest raspbmc compared to rasplex. 30-40% vs 60-70% for 720p 4Mbps and 40-70% vs 65%-96% for 1080p 8Mbps. There were occasional spikes near to 95% put they were very shortlasting and did not affect video playback which was perfect on the brief look. Also the menus were working very nicely both with the default Confluence and recommended Quartz skins.
But plexbmc is not not Plex, actually quite far from it. And since I used the suggested USB-stick data partition installation method I should try it also for rasplex. Just have to do some reading first.
Edit4: Re-installed to SD+USB combo using these instructions. CPU usage is pretty much at the same level but the stuttering/freezing is not present any more. Also the ui is much more responsive (but still not near the PC based PHT). I also experimented with the system/audio settings by enabling/disabling all the combinations but they did not have any effect on CPU usage on these sample videos (these might have been all DD5.1).
With the SD+USB installation method, I've finally reached a usability which allows experimental testing using other family members as guinea pigs ;)
