I posted this over at Reddit but didn’t get any response so I try here also.
I don’t know if this is intended or a bug but I noticed that my newly added TV shows doesn’t show up on the far left side of the “Home”-tab when they are added to the library. Quite difficult to explain it without showing how it looks but I can try to make an example:
If I read the Home tab from left to right it looks like this:
Show A | Show B | Show C | Show D
All of these shows are “old” and no new episodes added, some of them might even be ended.
What I see from time to time is that Show A-D are moving positions sometimes but they don’t move far out to the right, they might jump one or two steps and after a while end up in the first position again.
If I add a new show to the library, Show E, it should show up on the first position (is my guess) instead of Show A, the same way newly added Movies work?
But the new show ends up on a different position, sometimes likes this:
Show A | Show B | Show E | Show D | Show C
…and sometimes like this:
Show A | Show B | Show C | Show D | Show E
If I add a new episode to Show E, it still stays on the same position instead of moving to the first.
I don’t know if you understood a word of what I just explained but if you did, is this a bug or something wrong with my library?
Thanks!
Server Version#: 1.19.3.2852
Player Version#: 4.30.2
