Thanks for doing all that testing and giving me a thorough response!
Playback issues
I had all the specials set to “Watched”, but the series was “Unwatched”. Not sure why it started playing the Specials first.
Aired Date
If changing the aired date works, that’s one possible fix. I’d like to program a Plex server plugin to visually slot the special between episodes just like Jellyfin does (only learned it does this last night). Any idea where to start?
I want it visual, not hidden away behind auto-play as I won’t know I’m not supposed to click “episode 7” when wanting to play the next episode in the season. I won’t always click “play” on the series itself because I might forget.
TVDB ordering issues
Correct, TVDB DVD ordering doesn’t work correctly because it’s often lacking specials completely.
Surprisingly, Specials for anime don’t ever air, they typically only appear on disc; not even on streaming.
Absolute ordering seems to be restricted to 1 season and also has the same issue of not all episodes appearing.
Aired date might need to be manually changed for each one of these season-specific specials (Road to Hero is supposed to be watched after Season 1) because they released on disc, never on air. That means they’ll always come up after the season is over, not between episodes.
One Punch Man is supposed to play in this order for Season 1:
- s01e01 - The Strongest Man
- s01e02 - The Lone Cyborg
- s00e02 - The Pupil Who Is An Extremely Poor Talker
- s00e01 - A Shadow That Snuck Up Too Close
- s01e03 - The Obsessive Scientist
- s01e04 - The Modern Ninja
- s01e05 - The Ultimate Master
- s00e03 - The Ninja Who Is Too Complicated
- s01e06 - The Terrifying City
- s01e07 - The Ultimate Disciple
- s00e04 - Bang, Who Is Too Overbearing
- s01e08 - The Deep Sea King
- s01e09 - Unyielding Justice
- s00e05 - The Sisters Who Have Too Many Things Happening
- s01e10 - Unparalleled Peril
- s01e11 - The Dominator of the Universe
- s01e12 - The Strongest Hero
- s00e06 - The Murder Case That Is Too Impossible
I can confirm this because even the TVDB descriptions say “sometime before Episode 4…”. When watching the specials after Season 1, they don’t have the same impact because I have no context where the story’s at when they take place.
Ideally, they’d play in the order I showed above because that gives you the full-context, and the slot in perfectly. In fact, there’s a joke in one of the episodes that only makes sense if you watched the OVA right before it.
I have this issue with at least 6 other shows; potentially more. That’s just the small number I’ve counted thus far, and I keep buying more.
Also affects shows + movies
If you count situations where I put movies in collections with shows (possible with Absolute Series Scanner), it’s well over 50% of my library that runs into issues because TVDB doesn’t place them correctly.
An example is Re:Zero. TVDB puts “The Frozen Bond” (a movie) before season 1 starts. That makes sense chronologically, but it’s supposed to be watched after finishing season 1 as it gives away too much the story before you even begin.
Also for Re:Zero, TVDB has Memory Snow after Season 1 when it’s supposed to be watched after episode 6 when you don’t have as good of a grasp on the future of these characters.
