How could I correct the errors in the metadata?
Such as the wrong actor/actress.
Or is there some feedback channels?
Generally you’ll want to look over at https://www.themoviedb.org/ - this is where it would most likely be but it really depends how you have your libraries set up.
Could you explain the specific issue you’re seeing?
I am using the defaut agent setting, and there is only one agent “Plex Movie” at the lasted version of Plex.
e.g. “Gong Li” (Gong Li — The Movie Database (TMDB)) was mistakenly replaced by “Wu Yigong” (Wu Yigong — The Movie Database (TMDB)) in all her movies.
another example, “Ge You” (Ge You — The Movie Database (TMDB)) was mistakenly replaced by “Lu Qi” (Lu Qi — The Movie Database (TMDB)) in some movies.
And I checked the infos from https://www.themoviedb.org/, which are correct.
The plex movie agent must have done something wrong, please fix it.
See here: Why is Gong Li called Wu Yigong in Plex! - #7 by OttoKerner
Since this issue is there for months, do we have a ETA?
