I have PlexPass (Love it!!) I have enabled Guest access and allowed some library to “Guest”. When I have some guest at home and they have Plex player on their phone, how do they connect to /access my Guest Library? Will it be different if they login to their Plex on their mobile as “Google User”?
“Guest” only enables the guest user in your Plex home. It is meant for like if you have a TV in your living room or guest room that you ( or someone else in your Plex Home) has already signed into. so their viewing on your TV does not mess up your own view history.
It does not make random devices that a guest may bring over on local network get access.
When you “switch user” on on a device there will be a menu to select a user in your Plex Home and Guest will be one of them. and that user will have access to the libraries you gave it.
Ah! Thank you very much for explaining the “Guest” concept in Plex.
