How do i change downloaded data for a given series
I’m trying to add the UK television series “Father Brown” to my server but Plex is showing program details for the 1974 series instead of the newer version staring Mark Williams - can I change this or do I have to enter the details manually
Paul
Give Plex a hint which series it is, by including the year of the show in the folder name.
This show appears as “Father Brown (2013)” on TheTVDB for the same reason.
Perform the “Fix Match” procedure + “Search options”,
https://support.plex.tv/articles/201018497-fix-match-match/
but instead of typing in the show’s title, you use the ID number from the TheTVDB website.
Brilliant, that worked, thanks for your help
