How do I create a custom plex report?
Is there a way to create a custom Plex report? For example I’d like to export a list of all my movies, the actors, directors into a report. I saw somewhere that Plex uses SQL Lite. If true are there any directions on how to query the database? Does anyone know of other alternatives?
Thanks,
Mike
Settings > Server > Help > Download Database – if I remember correctly, the actual db is locked, the downloaded copy isn’t.
edit: yes, it’s a sqlite database
Export Tools Plug-In
@ChrisAWallace said:
https://forums.plex.tv/discussion/254248/rel-exporttools/p1
I second this… It’s a great plugin that will do exactly want you want.
