How do I delete the "Plex Versions" Folder?
Server Version#: Latest
Player Version#: Latest
How do I delete this folder?
I did not mean to create another version and I do not want to see this Folder in my Folder list.
I use Folders 24/7.
Please Help!
Delete
I have also deleted the converted version file however, this folder still remains.
I just figured it out.
You go to your Windows PC, log into your Shield via the Local Area Network with Windows Explorer, go to the area within the drive that holds your database files to where your “Optimized File” is and you will see the “Plex Versions” folder there next to the file.
Looks like Plex creates a standard folder to where your file is. However, you can’t delete it within Plex, you have to delete on the PC/OS level.
This is actually super easy. Just needed to do it one time.
Thanks!
