The theme music is really annoying and can’t find where to disable it for my Xbox one.
I’m doing this from memory so bear with me.
- Press the menu button on the controller. A menu will pop up, select settings to open the Settings screen.
- I believe it’s under advanced where you will find it, but from the settings menu it should be easy to find as there aren’t that many.
Ah thaks! Found it!
Great!!
This helped me too. Btw, the menu button is the one to the right of the big X guide button.
I didn’t know that menu existed until I read this post! The Xbox Plex help menu needs some work. Having one would be a good start
‘help menu’? We have help in the app, but where are you expecting to see it? Thanks!
