how do i download plex connect
where is link to download plex connect
Download link https://github.com/iBaa/PlexConnect/archive/master.zip
Install guide https://github.com/iBaa/PlexConnect/wiki
Depends on the host you will be using and if you would like to easily update, if you use git you can install/update easily doing this:
    # Installation
    git clone https://github.com/iBaa/PlexConnect.git
    # Updating
    cd PlexConnect
    git pull
What host are you planning on using for PlexConnect (for example mac, windows, linux etc)
