Hey, I am looking to remove the recently added movies and television on my dashboard how can I do this? I am using windows 10. I managed to remove the on-deck in the settings so far. Please help, Thanks!
I am doing this mainly because i noticed when i add a user(friend) they still see the dashboard of stuff they dont have access to and i would like to fox that some how
The only way is to edit all of your TV and Movie libraries and disable the “Include in dashboard” setting.
That would be a bug.
A user only sees stuff on the dashboard to which he also has access permissions.
If he sees something else, that would be either some error in the database or improper use of some other Plex feature or a malfunctioning Plugin.
You should verify that you only share those libraries on those Plex servers which you actually want to share.
It can’t hurt as well to check your Plex Media Server.log for messages about database corruption.
