How do I see the audio codec?
Hello, long time Plex user but call me thick - I just can’t work this out - say I have 3 albums the same but saved as different quality/codecs… how do I choose the one with the highest audio quality - in other words how do I see the audio codec/bitrate in the Fire TV app after searching for an album and getting multiple hits - the album covers all look the same?
Cheers :slight_smile:
Use the web app to determine the version which is losslessly encoded.
Use the plex media info.
Delete the other versions.
Hmmm, thanks OttoKerner, it’s most likely the right thing to do, it could take me a while, just thought there would be a way to see the codec info like in PlexAmp which doesn’t have a FireTV version. Not to worry, thanks for the reply :slight_smile:
