Hi there,
Hi there,
you put in the the plug-ins folder then it should show up in the freebase metadata agent ( you might have to relaunch the plex server). then you have to check it to enable it. and hit the gear for options
Thanks for the Quick answer!
But what do you mean putting in to the Plugin folder? I'm looking for that folder for hours now. I know ther should be one at .../Library/Application Support/... but there is none. Do I look on the right spot? when I downloaded the PMS I put it to my Programs (Mac) and when I started the program it opened directly the Web browser with no installing and i had full access. I hope I did a mistake and you can tell which one.
Thanks!
Thanks!
You are most likely looking in the wrong Library folder. Go to Finder, shift-cmd-G and type in:
~/Library/Application Support/Plex Media Server/
Then hit "Go". :)
look at my signature at the link (CORRECT LIBRARY)
~/Library/Application Support/Plex Media Server/Plug-ins/
the ~ means your user folder
Alright now I got the folder and it works thanks a lot guys.
