Good day, I would like to add some movies in a TV library. Is there any way to do that?
You can’t.
Unless these are some kind of ‘specials’ which relate directly to a tv show.
In which case you can add them as tv show episodes in the Season 00 (also called the ‘Specials’ season).
Try and find the movie in question on TheTVDB.com which will tell you the episode number you need to use in your file name (e.g. TV Show Title - s00e03 - Movie title.ext)
Thank you for the reply. Could I not just create a collection… or can I add to the name of the file S01e01 or something like that?
Of course this is always an option, in case the tv show and the movie are not very closely related. But then you don’t need to add the movie into the tv show library.
e.g. Ghost in the Shell
Not sure what you mean here.
OK here is the complete situation for the sake of clarity. I want a library where I keep all documentaries (TV shows and movies). Since there are more that are TV shows then I created a ‘TV’ library. Now I want a movie to show up (example Amazing Grace). Can I create a collection with only that or can I just go on the file name itself and add S00E01? I don’t need the matching to work (I can just add a poster after for aesthetics). Thanks
That’s simply not possible. It has always been like that for documentations.
Unless you can find your docu in one of the “meta” tv shows like https://www.thetvdb.com/series/bbc-documentaries or https://www.thetvdb.com/series/national-geographic-documentaries etc. then you have to place it into a “movie”-type library.
