How do I add a proxy?
I don’t see an option in setting.
bump for help
You need to give some more information on exactly what you are trying to accomplish. Are you talking about a web proxy? Reverse Proxy? The more information you can give the more likely you will get a helpful response.
Thanks for your reply!
I have been looking around and it seems I need to use a VPN, not a proxy.
Are there any videos how to do this?
I’ve looks and all i’ve seen is written tutorials that are hard to understand.
There are no settings within Plex that are VPN specific. If the Plex server is to be routed over the VPN and you want it publicly accessible you will need to make sure the port is opened by your VPN provider.
Without knowing what you are trying to accomplish I’m really at a loss as to how to even point you in the right direction.
