How to adjust library poster size on nvidia shield, one icon is +/- 90x45 cm large on screen
Server Version#: 1.22.0.4163 On Synology
Player Version#: 8.14.1.23548 on nvidia shield android
I’m watching with a beamer on a screen of 4 meter by 2,20 meter
On the screen are only 6 library icon posters in a row visible and half a row beneath them. The library icons are nearly 90x45 cm large.
On the windows player i have a slider to change the icon size, but on the Nvidia shield i can not find out how to reduce the size.
Does one off you know how to do
Jan
There is not an option to do so. The only apps that do are the desktops apps for the web browser and app and Mac/Windows app which share the same interface.
:sob:
