How to adjust the recording buffer
Hi is there a way to adjust the amount of time that the DVR records when you watch live tv?
Because when I pause the live tv on my Nvidia Shield TV for more than a couple of minute, after I play it again the playback will stop after maybe 2 or 3 minutes.
@jpgrenier, this has been an ongoing issue across various clients. If you search or look at threads like this one:
you will see that this behavior is not “working as designed/intended” currently and has been problematic for quite some time.
Thanks for the info, i didn’t see that thread. Seems like Plex is not trying to fix this bug because it’s been there since the beginning I started using Plex as my DVR(almost 2 yesrs ago). I’ll keep watching for some answers :crossed_fingers:
