How to find "Unmatched" movies?
How to find “Unmatched” movies?
Is there a way to filter unmatched movies?
How to find the discrepancy between number of files on disk and the number of movies in the Plex movie library
I found the following way to do this using a terminal, might be useful to others too since this thread is one of the top google results. I’ve only done it on a Mac, should work as long as you have access to a terminal and sqlite3.
First, open the database using the sqlite3 tool by running this in a terminal window (e.g. open Terminal.app on a Mac):
sqlite3 ~/Library/Application\ Support/Plex\ Media\ Server/Plug-in\ Support/Databases/com.plexapp.plugins.library.db
Second, run the following query:
SELECT title FROM metadata_items WHERE guid LIKE 'local://%';
That’s it.
