How to Go Home
On PlexAmp for Windows, once you click on the playlist button it seems like you can’t get back to the home screen. Or any other screen for that matter.
Am I missing something?
Thanks!
Do you mean when you start playback? if it is like the mac version click the down arrow at bottom of window then the normal navigation buttons should show
Plexamp_and_Applications
I think it’s after you press the down arrow. I see “Back to” "up next’ and “related” at the top. And then there is no way back.
No down arrow. No home button. Just stuck.
OK can you please take a screenshot of exactly what you see. I am not understanding what screen you are on.
I think you need to scroll up or resize the window. you are basically at the bottom of the page
Oh! That works. I’m in tablet mode so Windows didn’t allow for resizing. I did not realize it was scrolling.
Thanks!
