How to make Plex "fit to screen"??
Hey guys so I’m having an issue with my windows application where everything is just humongous on the screen, if I maximize the windows I see everything fine but some of the options are cut off by my windows taskbar. Is there anyway to resize this plex window?
Specifically when I click on a movie I want to click the “…” and click on “fix incorrect match” because the metadata is wrong. But because the window is so blown up it won’t show any options under “optimize…”
Currently there isn’t a way inside of Plex to correct this.
But, you can use the built in “zoom” feature of your Browser to allow you to see the cut-off area
Sounds like you have the DPI settings on your PC set to something over 100%. If this is the case… set those to 100%, log off and then back on to the PC. (Right click desktop, select personalize, click on display in the bottom right hand corner. This is where you will find the DPI or text size.)
Yeah i was having to access it through the browser but you’re right the DPI settings are too high… if only there was a way to adjust the DPI only for Plex.
@ZeusyZeus - I don’t know if it works on every browser and operating system, but if you hold down control on the keyboard and use the scroll wheel, you can zoom in and out. It might even remember the settings for the Plex pages.
I was having the same issue and your suggestion helped me out. Thanks! Glad I stumbled across this.
