One of the latest Plex releases for WebOS (LG) did drop the feature to switch from a movie detail on the Watchlist to my Library and play that movie there.
On the Watchlist there are only some Movie details, actors and trailers now. No play button, no switch from that page to the Movie library, nothing.
Currently I look in the Watchlist, go back to the main page and search for the movie from there. That’s really a step back from the previous releases.
Confirm I am seeing the same issue in LG webos 3. There is a brief spinning wheel stating looking for sources but then nothing and no option to play. On Samsung by contrast sources appear underneath controls to select source to play but this appears to be missing on LG web os.
Assume this is a bug. @markus101 are you able to confirm?
Confirming the same issue. There is a brief spinning wheel looking for available services but then the “available services” button(s) don’t even display and no option to play from the watchlist. The movies are in my libraries and I can get to play them from the library or the search tab. In the search tab if I look by movie name it displays “available services”. On PC by contrast, available services appear underneath controls in the watchlist to select available services to play but this appears to be missing on LG web os app. I’m sure that it was working OK before (a few weeks ago) because I was using watchlist extensively, and I even rolled the server back to an earlier version but the feature appears to be broken.
