How to Remove Scheduled Recordings?
On the Shield;
  1. I set a movie to record about a week ago.
  2. I watched it.
  3. I then deleted it.
Why does it’s entry remain in the recording schedule?
Same question. I’d like the ability (or instructions) to remove Recording Schedule history after a period of time or at least clean up the failed or removed recordings.
Same problem, how to delete scheduled recordings after watching them. They stay in recording and get an error when i select them
Recording schedule is a list of all recordings made it stays visible for 2 or 3 weeks, just as a record of what was recorded. I personally do not use the recording schedule to view recordings from, I use the recently added areas when you first access the server.
I am also still looking for how to remove recordings. These are recordings that I watched and deleted over a month ago, and they are still shown in the recording history. Plex is up to date with version 1.13.5.5332 on Windows 10.
What’s the point of leaving the recording schedule event after you have deleted the the recording. It’s not as if you can access it once it’s deleted. This is really annoying as it show recordings and just clutters thing up.
So this is normal? I just started using Plex and I was thinking I was doing something wrong. So when you record something, it shows up… you watch it… then you delete it, but it is supposed to stay in the list of recordings? This makes no sense. What am I missing?
I have just encountered the same issue. What are PLEX going to do about this?
Well, obviously, nothing. :frowning:
Same issue for me…
I’ve deleted some tv show directly from the livrary and now, I cannot delete the entries into the DVR Schedule menu…
Strange
