How to see Genre for audiobooks in Plex?
Server Version#: 1.29.1.6316
Hello,
I use Plex to manage my audiobooks. For my audiobooks library I have Scanner set to Plex Music Scanner and Agent Audnexus Agent.
I have “Keep existing genres in place” and “Prefer local metadata” ticked.
Genres source is set to “Embedded Tags”
It generally works pretty well, except that the genre I have in the file, does not show up in Plex from what I can see.
When I look at a file, it show all tags empty:
This is what Mediainfo shows, so what I would like is for Plex to show the Genre as “Communication Skills”
General
Complete name                            : Chris Voss -- Never Split the Difference.m4a
Format                                   : MPEG-4
Format profile                           : Apple audio with iTunes info
Codec ID                                 : M4A  (isom/iso2)
File size                                : 13.2 MiB
Duration                                 : 14 min 5 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 131 kb/s
Album                                    : Never Split the Difference
Track name                               : Never Split the Difference
Performer                                : Chris Voss
Genre                                    : Communication Skills
Audio
Format                                   : AAC LC
Format/Info                              : Advanced Audio Codec Low Complexity
Codec ID                                 : mp4a-40-2
Bit rate mode                            : Constant
Bit rate                                 : 132 kb/s
Channel(s)                               : 1 channel
Channel layout                           : C
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 13.1 MiB (99%)
Language                                 : English
Default                                  : Yes
Alternate group                          : 1
Thanks for any advice!
That is handled by the agent so you might want to go ask the author of that agent to see if it is suppose to populate those fields.
