I’m using the Plex docker container. I’d like to host Plex on port 443, but I already have a web server listening on that port. So I think this means I’d have to host plex behind a reverse proxy. Everything I’ve googled shows many many variations to configuring NGINX for this. Right now this is what I’m hoping for:
public PC -> Direct connect on port 443 -> My router 443 -> NGINX reverse proxy 443 -> Plex server on port 32400 (unencrypted)
Reason I think it should be unencrypted between the proxy & plex is that the reverse proxy already takes care of SSL, and it doesn’t make sense to waste doing both together.
I prefer a subpath domain, like https://domain.com/plex, but I am willing to do https://plex.domain.com if that’s easier.
Can anyone share some advice on how to do this? The reason I want to do this is because I like to access Plex from networks where the only outgoing ports allowed are 80 and 443. This means I can’t access my server using the normal set up, which requires port 32400 to be allowed out of the firewall.
Plex has a pretty complicated system for running SSL on their own terms, and I think that clients assume that they can talk directly to Plex on port 32400. I think it’d be difficult to work around Plex and try and force things through port 443.
See How to setup nginx as a reverse proxy for plex? for a working example Though, this is a subdomain solution. Context path related rules will likely be more complicacted. You have to live with a broken remote access display, as it uses ip instead of the domainname to perform it’s availability check.
