I’m trying to set up plex behind my NGINX reverse proxy to improve performance and avoid using plex servers as much as poss. I have the following config;
server {
listen 443 ssl;
listen [::]:443 ssl;server_name plex.*; include /config/nginx/ssl.conf; client_max_body_size 0; proxy_redirect off; proxy_buffering off; location / { include /config/nginx/proxy.conf; resolver 127.0.0.11 valid=30s; set $upstream_app plex; set $upstream_port 32400; set $upstream_proto http; proxy_pass $upstream_proto://$upstream_app:$upstream_port; proxy_set_header X-Plex-Client-Identifier $http_x_plex_client_identifier; proxy_set_header X-Plex-Device $http_x_plex_device; proxy_set_header X-Plex-Device-Name $http_x_plex_device_name; proxy_set_header X-Plex-Platform $http_x_plex_platform; proxy_set_header X-Plex-Platform-Version $http_x_plex_platform_version; proxy_set_header X-Plex-Product $http_x_plex_product; proxy_set_header X-Plex-Token $http_x_plex_token; proxy_set_header X-Plex-Version $http_x_plex_version; proxy_set_header X-Plex-Nocache $http_x_plex_nocache; proxy_set_header X-Plex-Provides $http_x_plex_provides; proxy_set_header X-Plex-Device-Vendor $http_x_plex_device_vendor; proxy_set_header X-Plex-Model $http_x_plex_model; }}
And i’ve added my url into the plex settings ‘https://plex.server.co.uk:443’.
When I hit plex.server.co.uk, i get a quick flash of 401 unauthorized then it redirects to ‘https://plex.server.co.uk/web/index.html’ where it just sits on the Plex logo that fills the screen, no prompt for login or taking me into the screen to see my media or anything. Am I missing something?
