I can’t find a way to upgrade on arm-based Raspberry
Use docker with arm64v8-latest images
https://hub.docker.com/r/linuxserver/plex/tags?page=1&name=arm
what command do i use?
You don’t use docker for now ?
it is not necessarily obvious if we do not know this system
But imo, I advise you to use docker, it allows isolation and automatic updates
Some links :
(install docker)
curl -sSL https://get.docker.com | sh
docker run \
-d \
--name plex \
--net host \
--restart always \
--volume PATH_TO_PLEX_CONFIG:/config \
--volume PATH_TO_MEDIA_FILES:/data \
linuxserver/plex:arm64v8-latest
and automatic updates ?
did the steps and still out of date
Ok, it’s difficult to explicate …
It doesnt update your old installation, it’s a new installation dockerized
so how do i remove the old one?
How did you install the old plex ? With .deb ?
wget -O - https: //dev2day .de /pms/dev2day-pms .gpg.key | sudo apt-key add -
echo "deb https://dev2day.de/pms/ stretch main" | sudo tee /etc/apt/sources .list.d /pms .list
sudo apt-get update
first desactivate the service
service plexmediaserver stop
Show me the result of docker ps -a
pi@raspberry:~ $ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
1b0758433f45 linuxserver/plex:arm32v7-latest “/init” 36 minutes ago Up 33 minutes plex
214a8d3d3dff hello-world “/hello” 13 days ago Exited (0) 13 days ago upbeat_dewdney
e8539f14dab7 hello-world “/hello” 13 days ago Exited (0) 13 days ago determined_mirzakhani
pi@raspberry:~ $
Plex is running, go to IP:.32400, dockerized plex could be respond
now the disk can not access
disk ??
hd (hd NTFS)
Do you set the correct path PATH_TO_MEDIA_FILES & PATH_TO_PLEX_CONFIG in the command ?
docker run \
-d \
--name plex \
--net host \
--restart always \
/mnt/usbj ust put this on? (usb path)
FYI: To update from my dev2day.de package to the official plex.tv package please read the migration guide at the end of the following thread:
