HTTP Control API Issues
Used to work now it doesn't
I can use the command ' http://10.0.1.10:32400/clients ' to see the clients running. My client has an IP of 10.0.1.12. I then try using any of the playback or navigation commands such as ' http://10.0.1.10:32400/system/players/10.0.1.12/navigation/moveDown ' and I get 404 errors. These commands used to work flawlessly for me through Safari and iRule remote app on my iPad, but not any more.
I am running PMS version 0.9.6.5 on a Synology 1512+ with a fixed IP and a client version 0.9.5.3 on a 2011 Mac Mini with a fixed IP as well.
Has anybody seen them work fine and then just stop working? Any ideas or help is greatly appreciated.
Check this thread if it’s a new issue ~ http://forums.plexapp.com/index.php/topic/43965-new-issues-in-the-last-day-or-two/
Thanks! That did the trick.
Thank you, this has helped me out twice now, although I wish it was easier to find... which is why I will now do this:
Linux Remote HTTP api no longer works after update, use this link
