I am using this docker for unraid. It says there is an update to Version 1.15.2.793, however it says to manually install. It’s my understanding that the docker must be updated. Will this docker get updated to that version soon?
Change the tag to public and restart your docker.
I tried that earlier, I had tag “latest” but all tags seem to be at the same version at this point, it was all last updated 3 months ago
The date on the public tag doesn’t matter, it is configured to pull the current plex image from the new repository.
You could try docker pull plexinc/pms-docker to re-pull the image if that doesn’t work then rebuild the docker.
WARNING:
So your success will depend on how well you built your docker file. If you properly assigned /config and /data to persistent volumes then nothing will be lost.
