Hello,
on one may device i use Kodi with the addon plex, and now i want to activate it.
But https://www.plex.tv/link the sign in does not work.
I have already tried it with a new password, nothing help
Hello,
If you are doing this on your phone or something make sure you phone keyboard is not putting an extra space after email/username/password as some do when autocompleting
if you are signed into browser on your computer to use forums then you should already be signed in. it should take you directly there.
@Handy_Man said:
Hello BigWheel,It works with my ipad, verry well, but not with my PC (Windows 7 Firefox).
In the forum I was also registered, it still not worked.
did you enter your email address/username?
Hi Kraevin,
of course, the same I have also made with my ipad.
With Internet Explorer it works (just tested), firefox is probably the error.
But can not say what it is, need some more tips.
Check Firefox for adware and third party addons that might be interfering.
The addons were not, all were disabled
But I refresh firefox, now it works.
Which setting caused the error, I can not say.
The problem is solved, Can mark somebody as Solveed, I do not know where.
Thanks to all who have supported me
I wish you all a nice, successful day
Handy_Man
need to sign in
