Huge PS4 Bug
Hello everyone,
I’m experiencing some big issues on the PS4 player.
It’s been 10 years I’m using Plex on PS4, and I never had any problem.
But out of nowhere, it’s been 2 days that the app can’t reach my server anymore. I keep having the same screen saying that I have to “Get my Plex Media Server”.
On top of that, the app is freezing. I can’t even explore the menu or the settings.
FYI all the other players in my home work fine.
I tried to delete and reinstall the PS4 player. It seems like there is nothing I can do to solve this.
Thanks a lot for your help.
Generally before anyone can help, you’ll need to provide things like the Plex version for your server, client (PS4), whether the server is on the local network or remote, etc etc. Good luck!
Server Version 4.22.2
PS4 Player Version 2.01
I’m using plex on the local network.
I have exactly same problem since at least 2 days, plex server is on last version, works on amazon fire tv but does not work anymore on ps4 client on same local network, with exactly same issues than original post.
Tried to uninstall but no changes.
In settings at https://app.plex.tv/desktop#!/settings/devices/pms how long ago does it show as seeing your server? Have you rebooted your server lately?
I have exactly same problem since at least 2 days, plex server is on last version on ps4 client Ans not work anymore…
Version ps4 2.01
Version computer 1.18.7.2457
Exactly the same problem here, do you need some additional information? I can use tablet or phone and watch the films using chromecast but I can’t use PS4
I don’t see the PS4pro there, I only see my computer.
I have uninstalled the PS4 app and installed and linked again.
Seem to happen right after PlayStation 4 update.
No answer at all?
I would like to add that I’m using Plex in the android of my smart TV without problem but the PS4 still isn’t working.
It seems that PS4 is totally abandoned by Plex developers
Same exact problem. Opened a thread about it. Didn’t manage to resolve it.
SOLVED thanks to Van_Helsing:
Inside Plex Server (not on PS4):
Change “Allow Fallback to Insecure Connections” to “Always” in Settings > General.
Change “Secure connections” to “Disabled” in Settings > Network.
I can’t believe plex support maintain these problems without an answer
Had The same problem. Solved also with The previous settings tweak. Thanks!
They just don;t respond to customers for months, wow.
Did you try this ^
Lol yes, EVERY FORUM “TIP”, I have tried EVERYTHING, re-installed plex on pc, on ps4, every setting possible, every IP address possible, nothing. Gave up, not worth the headache.
