I have a Coffee Lake 8700K with UHD 630 enabled, as well as a discrete GPU. Under Graphics Settings, I have it set to prefer the Power Saving GPU, the UHD 630. As I understand it, this iGPU has QSV.
When plex does it’s hw transcode, it seems to always request mf instead of QSV, even though QSV is higher up on the priority list. Does anyone have an answer as to why the transcoder does this? EDIT: When forcing the transcoder to use the Nvidia GPU, it also requests mf instead of NVEnc.
Also for the following combinations when transcoding on the same computer as the plex server, this happens:
Both Cards connected, 1070 Ti Active, UHD 630 not displayed to
Transcoder Setting | PMP Setting | Result
Power Saving | Power Saving | CPU Transcode, UHD 630 3D
Power Saving | High Performance | CPU Transcode, 1070 Ti 3D
High Performance | Power Saving | 1070 Ti Transcode, UHD 630 3D
High Performance | High Performance | 1070 Ti Transcode, 1070 Ti 3D
Direct Play | High Performance | Direct Play, 1070 Ti 3D
Both Cards connected, UHD 630 Active, 1070 Ti not displayed to
Power Saving | High Performance | CPU Transcode, Alternating between UHD 630 3D and 1070 Ti 3D
High Performance | High Performance | 1070 Ti Transcode, UHD 630 3D
Direct Play | High Performance | Direct Play, 1070 Ti Copy
Ideally, I’d like to have the UHD 630 doing the transcoding, and the 1070 Ti doing the displaying, but I just can’t get it to set as such.
When I transcode to my iPad this is what happens:
Power Saving | High Performance | UHD 630 Transcode
Additionally, 4K HEVC HDR transcoding seems to only be able to be done by the 1070 Ti, it defaults to CPU Transcoding when the Power Saving GPU is selected. However, 4K HEVC HDR Compressed seems to be able to be handled fine by either GPU. Is there are bitrate limit that can crash the iGPU?
