Months ago, I tested the free trial 1 month of premium and I was able to use hw transcode without problems. This Christmas I bought one plex lifetime pass, but hw transcoding is not working anymore. If I change to sw transcoding then everything’s fine, but as soon as I enable the HW transcoding, the video is stuttering and at a 0.2 fps while the sound is good.
I can reproduce video in original quality with and without hw transcoding without any problem.
In the Summary you can see a log but I think the important parts are:
Dec 25, 2019 15:56:27.744 [0x7fd3917fa700] Debug — [FFMPEG] - Direct mapping possible.
Dec 25, 2019 15:56:27.758 [0x7fd3917fa700] Debug — TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
So hw transcoding should be working. While it’s transcoding i’m getting:
Dec 25, 2019 15:56:28.507 [0x7fd391ffb700] Debug — Transcoder segment range: 0 - 0 (0)
Dec 25, 2019 15:56:28.508 [0x7fd34b7fe700] Debug — Transcoder segment range: 0 - 1 (0)
Dec 25, 2019 15:56:29.847 [0x7fd391ffb700] Debug — Transcoder segment range: 0 - 1 (1)
Dec 25, 2019 15:56:29.848 [0x7fd34bfff700] Debug — Transcoder segment range: 0 - 2 (1)
Dec 25, 2019 15:56:29.940 [0x7fd34b7fe700] Debug — Transcoder segment range: 0 - 2 (2)
Dec 25, 2019 15:56:29.942 [0x7fd391ffb700] Debug — Transcoder segment range: 0 - 3 (2)
every second as you can see in the logs.
Any idea?
Thank you
Linux: Ubuntu server LTS:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.3 LTS
Release: 18.04
Codename: bionic
Server Version#: plexmediaserver 1.18.3.2156-349e9837e
Player Version#: Last on android, ios, web and windows 10. Player is not the problem.
I can upload the zip logfile to get support.
