HW Transcoding (working for decoding only)
Server Version#: Version 1.19.5.3035
As I understand things there are 2 stages to transcoding (decoding and encoding) and both can benefit from hardware acceleration. However in Plex articles and on other sites, this is conflated and just called transcoding.
When I look at screenshots of hardware transcoding in Plex I see 3 versions:
1 - where both the decoding and the encoding have (hw) next to them
2 - where only the encoding (the 2nd line) has the (hw) next to it
3 - mine, where only the decoding (the 1st line) has the (hw) next to it
1 - common in forums
2 - from Plex site
3 - less common
What causes this difference?
there are limits like using a nvidia card and some others that are outlined here under encoding
Thanks Big wheel, that was the page that I got the Plex screen shot, I am basically asking is that page complete?
Why does it not explain this variation in transcoding marking on the dashboard?
Why does the screenshot on that page show only one part of the stream being hardware accelerated?
Basically, should step 7 on that page have more info?
Hardware can’t do everything and I’d guess an audio transcode is one of the things it can’t do. "Graphics’ - the audio doesn’t have any of it maybe
Thanks Juice.
I agree that I have not seen the (hw) next to audio on mine or other systems. So I assume that audio streams are transcoded by software.
What do you mean by "“Graphics’ - the audio doesn’t have any of it maybe
Well, Hardware is supported with your ‘Graphics’ card - which is really good at doing graphics and audio doesn’t have any graphics to process.
that’s User Logic - and may not mean anything
lol
in image #2 I believe it is not decoding because it an mpeg4.
do you have multiple streams going on at same time? are you using a Nvidia card?
single stream but on old h/w, so my iGPU on my SandyBridge CPU cannot activate as I have a Barts based ATI GPU.
So was my initial summary in the first post right?
There are 3 states of h/w transcoding and all three are supported by Plex?
I was wondering if sometimes it shows version 2 even where there is full transcoding.
yeah as far as I am aware
not sure what you mean by “full” transcoding. We usually use that term to mean both audio and video are being transcoded regardless if HW or not. So all three of those are full transcodes
sorry I meant h/w transcoding. IE in my first post, only image 1 is h/w transcoding, image 2 is h/w encoding and image 3 is hardware decoding
So in that context, I was wondering if image 2 is also used for h/w transcoding (ie also the decoding).
You suggested earlier “no” as mpg4 is not decoded in h/w
This is the way I see transcoding
In the old days when your media file was in a format your client would not accept, you simply couldn’t play it. One of the magic features of plex is that its’ clients recognize what they can handle and what they can’t play, and they share that with the server. When you try to play a file the client can’t handle, the server is instructed to change it to an acceptable format on the fly. This is transcoding.
Transcoding decodes the media file from the format it happens to be in, then it encodes it into the format required by the client. The container, audio, video, even subtitles can need to be transcoded. It does this while you are watching your media, a little bit at a time, sort of a just in time approach.
Your server CPU does both the encoding and the decoding tasks for all (container/audio/video/subtitles) of these items by default. If you had enough server CPU, everything would work perfectly. Unfortunately, we don’t always have enough server CPU, and that is where hardware-assisted transcoding comes in.
If you have
A) a plex pass
B) hardware acceleration enabled
C) Intel quicksync or NVENC/NVDEC hardware in your server
D) graphics driver on your server
then you have additional options for video only. You may be able to offload the video encode and/or the video decode to this extra hardware. It is important to note that these are separate processes and hardware acceleration will be used for one, both or neither process.
The items that determine if hardware assist kicks in are
  1. Plex has the support in your OS for this exact video format (it almost always does, but bugs happen)
  2. The graphics driver in your server has support for this exact video format (again, bugs happen)
  3. When decoding, your GPU hardware must support hw acceleration of the exact video format your source file happens to be in.
  4. When encoding your GPU hardware must supports hw acceleration of the exact video format your client needs.
For #1) you can ask here.
For #2 you can often find details in the driver release notes.
For #3 and #4 just check the table for intel here
and for Nvidia here
